Things to watch for with a sail drive
May 10, 2004
254
Hunter MH 37 Manitowoc, WI
Buying a new MH37 this spring. I want to stay off right. What things should I watch out for during commissioning to ensure success with s sail drive. The boat will be sailed on Lake Michigan. It looks like VC-17 I a a no-no. I'm considering Pacific Plus or TriLux 33 for bottom paint.
caguy
Sep 22, 2006
4,004
Make sure it has zincs. I have seen many that look like swiss cheese.
richk
Jan 24, 2007
495
Marlow-Hunter 37 Deep Creek off the Magothy River off ChesBay
I took delivery of my MH37 (sail drive) with a non-metallic bottom paint. Was told this was out of concern for the sail drive and galvanic action. You may want to check this out with the delivery dealer. BTW, mine's in salt, not fresh, water.
If it was my boat, I'd do a lot of research online PLUS make sure I fully understood the manuals that come with it. They are a design solution option to a standard straight shaft and require different maintenance techniques.
5,134
Bavaria 38E Alamitos Bay
When I have questions like this, I call one or more authorized factory representatives to get the required information. However, saildrives are sometimes anodized aluminum; should not need painting, but must be protected from electrolysis.
richk
Jan 24, 2007
495
refer to my last
see my previous posting on this. Kings Gambit's comment is why there isn't metallic paint on the bottom
Jan 10, 2015
1
Beneteau 423 Norfolk
Install a Galvanic Isolator, keep the zincs changed and check them monthly in case there in stray current running from other boats in your marina. Also change the oil as per manf. Always allow for oil to expand when the unit is running. Do not fill it up to the top, this will break the oil seals. Scott
