Thickness of Nav Station Wood
113
Hunter 340 Bremerton, WA up from Woodland
I am hoping that someone out there has done some work around the Nav Station or Galley areas on a 1998-2003 vintage Hunter. I am far removed from my 2001 H340 and need to know the thickness of the panel one is facing when sitting at the Nav Station, where instruments would typically be mounted. I presume it is 1/2, 5/8, or 3/4 and probably the same material the locker doors are made from. Anyone know?
May 24, 2004
470
Hunter 33.5 Portsmouth, RI
Steve, I cant speak for the 1998 - 2003 vintage, but on my 1990 H-33.5 the bulkhead/panel thickness is 12mm (~ 1/2"). I have made cut outs and checked it.
May 10, 2004
113
Thank you, Navigator. I will proceed with the presumption of 1/2".
