Thetford / Tecma Comfort Mate waste valve (joker) replacement
May 24, 2019
5
Hunter 35.5 Ludington, MI
Hi,
Thetford no longer makes (or handles) Tecma heads or parts thereto. So I can’t find the part (#41277), which needs to be replaced pretty much annually. Does anyone know of a suitable replacement (i.e. not one that simply fits in the waste tube); the Tecma part is fairly flexible, suggesting that the pump may not be strong enough for the more sturdy Jabso.
Any help is greatly appreciated.
Dec 2, 1997
9,011
- - LIttle Rock
This is the first I've heard that Thetford has discontinued Tecma and Tecma toilets still show up their website Tecma Permanent Sanitation | Thetford Marine and it's still possible to click on each of the Tecma models. However, the link to "distributors and service locations" no longer seems to work, so I need to find out more about this.
What is part # 41277 ? Sounds like it's a joker valve. If so, check out the Raritan joker valves. If not I'll try to find a comparable brand that'll work.
The original Italian Tecma mfr wasn't happy with the quality of Thetford's version and has introduced a new toilet that's very similar and is sold in the US. I'll have to find out what they named it...it's possible you can get the part you need from their US distributor/retailers.
So stand by...it make take me a few days.
--Peggie
9,011
- - LIttle Rock
Aha...the distributor-service center link DOES work...it's just very slow and not easy to navigate when it does. Choose your country (USA) in the search box and the map will change to US and find the one in or near MI. Please post the results.
I just saved you some work...it looks like this one will work:
Grand Bay Marine
291 US-31
49685, Traverse City
Michigan
U.S.A.
Directions
Website
Phone: 231 943 0333
--Peggie
May 24, 2019
5
HI Peggy,
Thanks for your work on this. I had called the Ann Arbor office (where, two years ago, I bought a set of two joker valves) and learned that the Tecma Comfortmate had been discontinued, and is no longer supported. There was no suggestion of a replacement / substitute, and nothing they could do for me. I think i have already called Grand Bay Marine, but will try again.
A guy at HeadSync.com has been the most helpful, and recommended the Jabsco 1.5 in. valve. However, the outer flange is so close to the “flaps” (I don’t know the term) that, once I cut that flange off, I think the valve would distort within the tube and then block everything up. The only solution I can think of is the Raritan 1.5 in “vortex” (I think it is called), because it has a longer body between flaps and flange. So, I could perhaps install it (with the help of a heat gun) over the Tecma hard plastic fitting and then the waste tube over the valve body. (Tecma is apparently metric, and its valve part has an OD of 1.41 in.) However, the Raritan is reported to be a bit more sturdy than a Jabsco, and so the force of the Tecma pump becomes an issue again.
The other possibility is to get a smaller size valve and use some sort of plumbing tape (self-adhesive) to “fatten” the OD of that smaller valve so it fits within the existing apertures.
Or, I could step the waste tube down (or up) to fit a more standard joker valve.
And all this to save having to buy a completely new head, for want of a joker valve. (The joke being on me, I guess).
I was hoping that I was not alone in this quandary and that somebody else had figured this out. But that is where things stand.
Any help, again, is greatly appreciated.
cheers
Dan
Dec 2, 1997
9,011
- - LIttle Rock
One more possibility: The Italian mfr who originally made Tecma wasn't impressed with Thetford's version of it and brought out a competitor they named the Planus. The US distributor/dealer is a company named Aquamare in Florida. I don't know whether the Planus "one way valve" (joker valve) can replace the one in the Tecma Comfortmate, but you have nothing to lose by calling 'em to find out...phone number is on the Aquamare website
--Peggie
