Reality check
Thermoelectric cooling sucks. The Peltier (sp?) effect, essentially running a thermocouple in reverse, was discovered over a century ago, and it's not taken the refigeration world by storm because:It's very inefficient. It takes a *lot* of electricity to run a Peltier effect module and unless the laws of physics change, it always will. A typical evaporative cycle reefer is much more efficient. You'll burn up the money you save keeping you're batteries charged in short order.It has limited capabilities. The lowest temperature the cooling module can achieve is a direct function of the heat sink module temperature, again because of the laws of physics. The best achievable differential is 40 degrees, which means a 55 degree box temperature in 95 degree weather. So, it works better the colder the environment, exactly backwards! Therefore you have to be in a 70 degree or colder environment if you actually want to freeze things! And the unit will be working very hard to do so. Isn't ice one of the great blessings of onboard refrigeration?On to the manufacturer's spiel. They're blowing smoke up the buyer's a** bigtime! Towit:Their unit is efficient? Compared to what, a rock and a stick? Thermoelectric is remarkably *inefficient* compared to evaporative systems. Their amp consumption numbers are stacked by assuming a *very well insulated* box (4+ inches)and intermittant operation. Rest assured in your moderately insulated box (2-3")the bugger will be running full time, consuming great gobs of juice.Their unit is simple? Well, if you go with air cooling I suppose so, but as you increase in size you gotta blow one heck of a lotta air over an aircooled sink, so the solution is water cooling? Talk about complexity, the maintenance on a seawater cooled system (keeping the crap out of it) will drive you up the wall. And adding water cooling ups the price to where evaporative systems compete handily.Note most units include a low voltage cutoff feature, undoubtedly because of owner's screams about overnight dead batteries. And they DON'T talk about the fact these units can't freeze a thing unless you live in Alaska. Contemplate this, a summer Sea of Cortez day pushes 100 degrees with water temps pushing the 90s. With your "thermocool" unit your goodies will be heading south at 50 or 60 degrees temperature fast!BTW, I owned a thermoelectric cooled refer for a coupla years long ago. It ran continuously in summer for about a 70 amp per day drain, and only worked well in the dead of winter, when a cardboard box in the cockpit would have done just as well.Spend your money on a compressor based unit and you'll be a much happier camper. Can you say ice cream?
