I'm removing a through hull on the bottom of my bow. I'm interested in advice on how to approach this. Here's some info on the current status:
- Hole size is 2 3/8"
- The glass was originally about 1/2" thick
- I've tapered it down to about 1/4"
- Tape is no less than 2" from edge of hole on all sides. I did not go past the centerline in an effort to preserve the shape of the hull
- We're seeing 50-70F weather right now
- Is this enough of a taper?
- I'm concerned about the fiberglass staying in place when its wet since this repair is essentially on the bottom side of the hull. Any advice on keeping it in place?
- Would you start this repair on the inside or outside of the hull?
- Any advice on avoiding air bubbles when mixing filler?
