A
Aldo
Last Saturday, I backed the trailer into the water to pull the boat out for the season. I used the ramp that I always use, and after backing it in my son yelled, "The trailer is floating!" It wasn't actually floating, but what happened was that the port bunk board that the boat sits on, floated off of the mounts because the heads of the carrige bolts were rusted small, and the wood around the carrige bolts was so soft that the board floated free of the mounts. My question is, Has anyone replaced their bunk boards with pressure treated wood? Could you bend the pressure treated wood enough to conform to the shape of the hull? What wood was originally used for the bunk boards? Mine lasted 21 years, and if I put stainless steel fender washers onto the bolts on the new boards that I make, I should be good for even more years. (I'll be old by then). I have to admit that when my boat is in the water, I never think about the trailer, except to keep plenty of grease in the buddy bearings. When the boat is out of the water I never think about it much either. Aldo
