The time has come for antifoul
93
Hunter. 260 Farr 40.7 Albany-
Looks like the 260 might be living more of its life in the water than out.
So need to antifoul her. Any photos of a 260 on props (on the hard) tips and general advice appreciated. :doh:
Jun 2, 2004
5,802
So you are thinking your boat has to come off of the trailer in order to be painted? I think most 260 owners do bottom paint while on the trailer. With some jacks and lumber you can drop one bunk at a time if that is your concern. Or you could have a marina launch it in the slings and finish the paint while it is hanging.
Not sure what paint is recommended for your area. I am still trying to decide if I get any better results from the expensive Petit that I sometimes use compared to the cheaper West Marine brand. I always used modified-epoxy in Lake Erie but switched to ablative when I went to Tampa. Now back on Erie I will stay with the ablative. My boat was in the salt water from October 2008 to November 2010 with two coats of ablative. Looked at her today and there are very few bare spots. That with the WM brand.
May 16, 2007
1,509
Boatless ! 26 Ottawa, Ontario
I want to do the bottom of my 260 as well. There are some pictures in the owners resources section of this site showing how one fellow did it on the trailer.
I will probably use VC17 on mine, I used it on my last boat and was very happy with it for freshwater use and even had the boat in the Keys for 2 months and it worked well.
The problem with doing it on the trailer is that you will not be able to do a proper job on the center board and trunk, really need to have about 2 feet of space under the boat to remove it. It is probably also time to change the center board uphaul line and you need to lift the boat to do that anyways.
Also you need to be cautious in sanding the bottom of the hull to prevent future blister issues, do only very light sanding. If you ever will want to apply a barrier coat to this boat now would be the time to do it before any bottom paint has ever been applied.
I intend to use a cradle for a 270 to work on my boat this spring once the 270 is in the water. I will probably apply a barrier coat first then the VC17 and change the center board line as well, it will be easy to maintain the VC17 after that because it does not need any sanding to recoat it every few years, so I hope to do most of it on the trailer after that.
Let us know how you make out, Bob
May 17, 2010
99
hunter 33 marina del rey
Practical Sailor has in their 2010 issues a very good long term test of most of the bottom paints. It was also done at two different sites on the east coast. there were some fairly large differences between brands. Also on types within brands.
