weigh movement
A couple of things I did on our 34. Moved the holding tank from the settee to the V berth. Had to remove the drawers under the berth to accomplish this. Then moved the batteries to the old holding tank location. Installed vent to overboard to vent battery compartment. This gets the battery weight down low near the keel. It also gets some weight out of the aft and into the bow. That helps with performance, as once the crew is added to the cockpit, it tends to sink the aft end. We now have zero list. Our plan is to next remove the bulkhead in the stern cabin under the cockpit, and make the berth go side to side. That will require moving the fuel tank to the rear of the boat, behind the rudder tube. Looks like this is not too bad, and will probably buy a new fuel tank to match the space. This will also help the starboard weight problems. Dave
