The singing yellow strap
255
Gloucester 20 Kanawha River, Winfield, WV
I have one of those big yellow ratchet-straps that I use to tie my boat to its trailer. The side with the ratchet on it is fine, but the all-strap side vibrates like crazy at highway speed. Enough so that it sometimes leaves a scuff mark on the hull at the closest point. Any suggestions on how to stop it from oscillating or something else I should be using?
Ross
Jun 15, 2004
14,693
Run a tie from the middle of one of the straps to the middle of the next. You have to change the resonant frequency of the strap.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
A couple of twists in the strap, on either side, and leaving it flat over the boat will prevent it from singing...
caguy
Sep 22, 2006
4,004
Twisting it also gives it some elasticity.
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
Everybody - let's do the (strap) twist! :dance:. It works!
Plus, we put rags or socks between the strap and the hull.
