Dinks
You almost always get what you pay for.You should consider how long you will have the dink and how you will use it before comparing value. A lower purchase cost up front may actually wind up costing you more in the long run should you have to replace an inferior product.Hypalon is by far the way to go if you leave the dink in the sun, subject it to abrasion, gasoline spills, etc. To get a good idea on performance of various dinks you may want to check out the Practical Sailor article on dinks that appeared recently. You can order it off their internet sight, or I will be glad to send you my copy. Look for my e-mail address in the 336 owners list.I also was considering the purchase of a dink (new or used). I researched models, asked owners of various models at my marina, talked to salesman at boat shows, checked e-bay, etc.Nowhere could I find the one on one critique that PS had done. My hats off to them.After reading the article I purchased an Achilles with air inflatable floor. Weight was a consideration, as was price, storage, and all Hypalon construction. The Avon's air floor is PVC. Defender had a sale on last years overstocked models so I saved a few hundred bucks too.I am sure there is not a one size fits all dink, but the article may help you find the one that fits your needs.Good Luck
