The Half-Witted Sailor
Apr 22, 2025
38
Morgan 321 0 Fair Haven
Now that the Great Lakes sailing season is over and the boat has been put to bed, I've had to time to reflect on all the stupid things I've done this year and how I have or will correct my ways. I thought I'd share some of them with you for a good laugh.
First up was the day I finally launched the boat for the first time. We set the boat in the water and the marina manager told me to start the engine and let it run for a bit before they dropped the straps. It roared to life just as it had when I tested it in the stands to make sure everything worked before the launch. Sure enough, after 10 minutes the engine died. The PO told me he had changed the engine filters the prior year before putting it in storage for the winter. I took the secondary filter housing off and noticed the o-ring looked a lot thinner than the o-ring in the box of spares he had given me. I changed that and the filter and tried to bleed the lines to the engine but, despite me pumping the lever on the fuel pump what seemed like a hundred times, I couldn't get any fuel to come out of the loosened connections. Luckily, one of the crane operators knew the local diesel engine expert and gave him a call. When he showed up, he noticed right away that I was missing a copper washer on a fitting. I was given a box of them in various sizes by the PO and he found the correct one and replaced it. Then he showed me the decompression levers for the cylinders and told me to crank the engine for a few seconds with the stop cable pulled. Sure enough, fuel came squirting out. We bled the entire system that way and started the engine again. It kept running and after that I felt much more comfortable for the journey to my new slip about 10 miles down the shoreline.
It was a beautiful sunny day, about 80 degrees with only a slight breeze on Lake Ontario as I pulled out of Oswego harbor for the trip to my new slip. I was going to motor the entire way since I hadn't bent on any sails yet. I felt confident all was well with the engine and turned west about 1/2 mile out. I had my charts, binoculars, hand-held VHF, and my hand-held gps, set a course to keep me in over 100 feet of water and pushed the boat up to about 5-1/2 knots. The boat was handling well and I relaxed a bit with my foot on the wheel and keeping an eye out for the fishing charters that occasionally passed by. I knew the landmarks since I've lived and recreated on this lake shore for over 40 years so figured I had it all planned out. About the time I was expecting my turn to shore, nothing looked familiar. I consulted the chart in the area around the inlet to the bay but nothing matched up. Then I looked at the gps (which I didn't think I'd need) and plotted the coordinates. Turned out that I was so busy looking at the sights around me and not paying attention to my position that I was almost 7 miles past the inlet. I turned around and started watching the shore a little closer and made it in to the marina and my slip. No one was around in the marina to see my landing so, of course, I turned in and came to a complete stop about 8" from the finger pier and right in position to step off the boat and cleat all 4 dock lines at a leisurely pace. I said to myself as I stood up from the final line, "I'll never do that again." :huh:
Stupid Trick #2: A few days later, I had a neighbor (an 86 year young old-timer) that helped me get the mainsail installed. I hadn't bothered with the jib yet because I was waiting for the PO to find some time to answer a couple questions on the mid-boom traveler and while he was at it could show me any gotchas getting the jib in the furler foil. A few days later, I had the bright idea that I was going to go out in the middle of the bay and hoist the mainsail and see how the boat handled with that alone. It was in the middle of the week so all the working stiffs were working and not sitting in the marina gawking at the new guy or zipping around the bay on their pontoon boats. We had a slight northerly breeze blowing into the bay from Lake Ontario. I motored out into the middle of the bay and turned directly into the wind. I put the transmission in neutral, jumped up onto the cabin top at the mast, pulled off the sail ties and started hoisting the main. About half way up, I put a couple wraps on the winch and started grinding. I didn't get too far with shaking out the sail and tailing the winch before I got an override. I quickly unwound the halyard and dropped the main a little to try again. Re-wrapped the halyard on the winch and cranked away. All well and good except, while I was fiddling with the winch, I hadn't realized or noticed that I had enough freeboard for the wind to catch and pivot the bow 45 degrees off the wind. By the time I got the mainsail about 3/4 of the way up, the sail had filled and the boom started pushing me closer to the edge of the cabin top and boat to start heeling. Ooops! Dropped the sail, tied it loosely with a couple sail ties and jumped back into the cockpit. I put it gear, turned it south and went back down the bay to give it another try. I did this 3 times, each time the wind caught the bow and swung the boat enough for the boom to push me back nearer the edge of cabin before I could get the sail all the way up. At least I didn't get an override on the winch on the follow-up tries. By then I was frustrated and said the h*ell with it and motored back to the marina. In the meantime, my 86yo neighbor had showed up for his daily sail and had watched my smart moves. When I got tied up in my slip, he came over and I mentioned my "problems" getting the sail up. At this point, he said, "why didn't you turn the autopilot on to keep your heading as you cranked the sail up?" :banghead: FOREHEAD SLAP.
Stupid Trick #3: I'd gotten pretty comfortable getting the sail up in the bay before I ventured out on to Lake Ontario. I figured why waste time in the bay and just go out on the lake and put the mailsail up there. I motored out onto the lake for about 1/4 mile in 5-8 knots of wind coming out of the north. Of course, this means the wind had the entire fetch across to Canada to help get those waves kicked up to about 3 feet in height. I was comfortable in the cockpit and the boat was handling the waves fine. What I didn't realize was the difference in my ability to stand up in the cockpit versus at the mast to raise the sail. By the time I got near the mast, I was having a hard time just standing and holding the boom; nevermind pulling off the sail ties and then hoisting the sail. At least I was smart enough to have my pfd on and the portable VHF clipped to the pfd strap. It was about this time that the "rogue" wave, you know -- the one that's a little bigger and not the same period as the ones around it, shows up and I could feel myself beginning to be thrown off the deck. I wrapped my arm around the boom and hung on until I felt stable enough to get back to the cockpit. It was about this time I decided to call it a day and plan to hoist the sail in the bay before venturing out on a windy lake again. :laugh: NOTE TO SELF: Buy harnesses and jacklines before doing that again.
That's just a few of my first year's adventures. I could go on but I think you get the gist. At least I won't make the same mistakes again and it frees me up to do other stupid antics next season. Hope you got a chuckle. I still do thinking back on it.
In the meantime, I wish all of you Happy Holidays!
P.S. Season 2 of Gilligan's Adventures is scheduled to begin in about 5 months.
Nice writeup Trapper John. Discovering a new boat is a load of fun. It is nice you have a “young Old Guy” as a mentor. Recognizing your sailing experience “history” can mean you are not going to repeat it.
I particularly enjoyed the part where you engaged in your first cruise that you missed your inlet. Those are great moments to experience out on the water. Being in the present, feeling the boat glide through the water, relishing the sunshine, never mind having to reverse course the experience was worth it.
Dec 25, 2000
6,070
Oh John, how I wish that were true in my case. :) Merry Christmas.
Shall we try again for Desolation Sound this coming season? I'm game.
4,049
Corsair F-24 MK I Deale, MD
a. Once on my cruising cat I changed the fuel filters but forgot to open the valves when finished. The engines ran just until I was between the jetties in a 25 knot cross wind. I shot into the wind, anchored (it should always be ready) very quickly, and then realized my simple error.
b. I sailed a few miles past my home port at the end of a lesuily DELMARVA circumnavigation once. It was a very nice day.
c. I leave my jacklines rigged full time. You never know. Replace them regularly. Cheap.
  • Helpful
6,014
Oday 322 East Chicago, IN
I’ve needed a tow into my marina 2 times…and both were ”self-inflicted”:
1) I was sure I could self-rescue should I ever fall of the boat…if I had a rope trailing behind. One day I forgot it was back there, and when I sailed back to the marina and slowed down, the rope got caught in the prop. Killed the engine…rope tight as could be around the shaft. Buddy came out and got me.
2) My son and I were out for a really nice sail and he was at the helm. I was bored so thought I would take care of some maintenance items…checked the 2 batteries and decided they both needed watering. Dumped a lot of water in Each cell (apparently I was late in my maintenance routine). While I was wrapping up the watering, my so. Yells “hey dad, the instruments all went out”. Huh? I ran over to the panel and checked the voltage…dang. Apparently you can dilute the electrolyte and drop the voltage dramatically. We sailed back to the entrance of the marina and another guy pulled me in.
Bonus - this one didn’t require A tow, but I went out on a day I should have stayed in the marina. Backing out of the slip, a line that was hanging on the stern rail dropped into the water. I was near WOT in reverse backing against the wind and if I stopped I would get pushed onto the rocks. I notice the rope getting tight and I grabbed it, but it snapped about that time. I put the tranny in FWD and prayed the engine didn’t die. Seemed OK, so motored out of the marina. Big waves and big wind, but I pressed on and got small sails out. Actually a nice sail once things settled down, but the bow was plunging into the waves pretty hard. One big wave and the bow plows u def the water. All of a sudden, I hear a strange sound…I keep thinking the rigging is coming down or something…it was tangible…I could feel a vibration under me feet…then I noticed, as the bow came up out of the wave. That the anchor is missing! The noice was the chain playing out over the bow roller as 35 feet of chain was going down with the anchor. I set the AP and crawled forward in the big seas to try and get the anchor back aboard. Lucking, the chain/rope splice caught on the roller and kept the 200 feet rode going down too. I was In 50 feet of water, so I don’t think that the anchor actually hit the bottom.
I dragged the anchor back on deck, crawled back to the cockpit, grabbed my iPad and hosted a Zoom call with some family members. I was out of breath, but didn’t let on to my wife all of the excitement I experienced on that solo sail!
Life would be boring without doing some dumb sh!t.
Greg
  • Ha
More is learned from making mistakes then doing it right the first time. :biggrin:
A few years ago I installed a new high output alternator. After installing, I started up the diesel and no out put. Checked the connections, checked the regulator, still no output. Pulled the alternator, took it to a shop, they couldn't find anything wrong or right with it. Sent it back to Balmar, they said all was good, (and probably a few other things they didn't share with me). Reinstalled the alternator, and it still didn't work. After staring at and puzzling over the engine I noticed the service disconnect switch was in the off position. Switched it to on, and guess what? It worked and continued to work for a couple of years until a yard tech broke the temp sensor, but that's another long story.
We've all done dumb things and gotten away with it. The important thing is learning from the mistakes. Ask your mentor about his friend who ended up on a break wall one October evening and had to be rescued by the CG.
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
I've got over fifty years cruisng experience on Lakes Michigan and Ontario. Pulled into Fairhaven a couple of times and stayed at Pleasant Beach both times. At 76, my cruising days are over, but I do have some suggestions for you. One is to cruise the coast in 20-30 feet of water - not 100 feet. This will allow you to easily see when you get to your destination. The shores of Lake Ontario has few hazards so there is no need to stay in deep water. Be sure to have a set of paper charts and study them the night before your passage. Once you get into the Thousand Islands you do need to be more alert to shoals.
If you are going to single hand you absolutely need a safety harness and jack lines. The safety harness should be an inflatable vest with a quick release at its attachment. If you are in front of the shrouds and go over you will get swept back to the shrouds and will never be able to get back on board if you are on the high side. If you are on the low side and the boat is heeled and you are in good physical condition you stand a chance. I used to have a strap hanging attached to the stern with loops in it to use as a ladder. Problem is, if you go over in front of the shrouds you have to devise a way to get to the stern. If your on AP and traveling at 5 kts that is going to be a challenge. My cockpit rail was shoulder high so I did not wear a vest while in the cockpit, but if I had to go on deck I NEVER did so without the tether and life vest.
  • Helpful
If one goes overboard with a tether they will drown. The point of jack lines and tethers is to keep someone on board. The problem is the tether attaches to the chest and will pull the wearer's head underwater. The jack line needs to be run down the center of the boat and the tether shorter than half the beam of the boat.
Likes: StuartSailor
ShawnL
Jul 29, 2020
235
Catalina 22 3603 Calumet Mi
To quote Captain Ron -- If it's going to happen, it's going to happen out there. I sail a Catalina 22 on Lake Superior and have had my share of "fun" even in that small of a boat.
Wow, it looks windy out there. Wife -- that'll make for good sailing, if it's too windy, we'll just head for that bay. We were never able to raise sails and never made it to the bay. Ended up motoring out for 20 minute, and then back for 40 in 4' waves. The boat was fine, we were wet and even the dingy ride back to the dock was unpleasant.
We've never been to that bay, that looks like fun. The bay was great, and we had decent wind. Until we decided we should turn and head for home and the wind died. And of course we knew we didn't have a lot of fuel, but it was fine because there was plenty of wind. Until there wasn't. Just made it back to our mooring and had about 1/4" of fuel in the tank. It had been on empty for a while, but I was holding it so the pickup (to the outboard) was in the deepest point of the tank while steering.
A couple of days later, we bring some fuel out and decided since there's no wind, we'll motor into town and hit the farmer's market. The gas can had other ideas and decided to dump fuel into the cockpit as we were filling up (collar broke on the fuel can we brought with us). Did get to the farmer's market, but also walked to the hardware store for some extra paper towels and bio-safe cleaner because the cockpit floor was slippery with 2-stroke fuel.
The list goes on. It happens to all of us (probably more than we'll admit). All you can do is go with it, and have as much fun as you can.
Sep 24, 2018
4,805
Catalina 30 MKIII Chicago
@TrapperJohn I'd say you had a pretty good first season
Here's how the maiden voyage of my last boat went...
After a grueling few months of semi-major repairs on a new to me boat I finally launched. The marina we were at in Michigan City, IN was two miles down a river. We had installed an outboard bracket, taking the advice on placement from another O'Day 25 owner at the yard. We did a lot of last minute prep the night before and setup a fan ran off of an inverter while we slept onboard. This ran the battery down most of the way but our outboard had pull start so we weren't worried.
We pulled out of the slip with what felt like a huge boat. We came to the bridge and it was wide open. We nervously approached and made it through. The wind was blowing strong and the motor kept dieing at idle making it very difficult to control a new boat in a small river. It was quite nerve racking but we had made it past the worst of it right? Nope! there was a draw bridge! We came to a screeching halt. Trying to keep a boat in one place so we could read the sign was not easy for a beginner. We hopped on the radio as instructed and requested a bridge lift. We passed through and came to one final bend in the river. I could see the big waves and to me that meant a great sailing day. I had a big grin on my face while the admiral was hanging on for dear life.
We get on the lake with a Southerly wind. I wanted to head South but the admiral insisted we go south. Too tired to argue I complied. We had a lively sail despite the genoa wrapping around the furler. After an hour or two we were ready to head back. We fired up the outboard and started to head down south. All was well for 20-30 minutes. Then I heard the sound of the outboard change drastically.
I looked back and saw it was dangling by control cables and the fuel hose! I immediately shut it down. For the next 45 minutes I was dangling over the stern trying to dead lift this 100lbs motor out of the water while fighting nausea. Apparently the likelyhood of sea sickness increases when one is bobbing around upside down. The transom had all kinds of blue paint marks on it but it was on board. Exhausted, I took a 20 minute break as we drifted north. I got the motor back on its mount and started it up.
Unfortunately, we forgot our jerry can at the dock. I knew we were low on gas but there was fuel in the tank for the semi-functioning inboard. As soon as I climbed below to get some fuel out, the outboard died. The batteries didn't have enough of a charge to pump fuel out (not that I knew how without bypassing wiring) much less start the ancient beast. We were officially adrift once again.
We attempted to sail back but the wind was coming from the exact direction we wanted to go. We also knew that sailing two miles down a small winding river was impossible. We called our insurance company to take advantage of the on water towing we had paid for. We were told that TowBoatUS was at the Scene party in Chicago and that we should call the coast guard. By this point the waves had grown to three feet and the sun was setting. We were reluctant to call the coast guard because there was no dangerous emergency but we did as instructed. They were helpful but we had a tough time getting our GPS coordinates from our phone but eventually we got it. They said they would be there as soon as they could.
We had virtually no food and water and continued to fight off sea sickness. There was almost no horizon visible and the conditions continued to get worse. We kept in contact with the coast guard by phone while we waited. It was dark and were instructed to try to turn on some lights. Luckily the mast lights came on.
After a two hour wait we see the lights of a boat in the distance. It continued to get closer. We turned on the flashlight for our one phone that still had a charge and started waving around. 30 seconds later we see the boat turn towards us. It came into view. It was the coast guard.
By this point the waves were in the realm of 4-6'. They appeared to be 8' above us one second and 8' below us the next. They debated on what to do. We could tell that the experienced captain was getting frustrated with his novice crew. Eventually they presented a fancy boat hook with a line attached to it. One guy put it out over the water in front of our bow. He waited for a few seconds and then in a split second got the line hooked on to our bow eye on the first try. It was truly impressive!
We were told that we would not be going back to our marina and that it would be a smoother ride going up North. We did not care at that point. We just wanted to be on solid ground. When we got to a port about 30 minutes later. We were told that they were going to hip tow us into a slip. They tied our boats together and off we went. It was a jolting ride. 25' sailboats aren't meant to be manhandled by a Coast Guard boat with 500hp hanging off the back.
We finally got tied up to the dock. They did an inspection and paperwork. We were given a warning for having expired fire extinguishers but assumed that our lights that were out was due to a low battery. They were very nice and we were incredibly thankful for all their help.
Now we were starving and in a completely foreign marina. It was about 11:30PM. We left our marina around 2PM and hadn't eaten since. We spotted a bar that was open within walking distance. It was the most beautiful sight we had seen in a log time. We ordered some stiff drinks and food. When our waitress got back we asked where we were. Apparently we had drifted into Michigan! We told her about our little adventure and we all had a good laugh about. Our food finally came. What was supposed to be tacos was basically essentially sauce and lettuce on tortillas. I didn't care. I had never been so happy to pay $16 for lettuce and tortillas in my life.
We got back to the boat. Hooked up to dock power to recharge and quickly passed out. The next morning we got breakfast from a lovely little diner in New Buffalo and made our rounds buying fire extinguishers, jerry cans, gas and a bunch of other essentials. I got the inboard up and running and we headed out around noon.
The outboard seemed to be moving a bit more than usual as we pulled into the fuel dock to fill up the inboard tank. I didn't think much of it as it was a cheap motor mount I bought off of ebay. Finally we leave the port. About 15 minute into our journey I heard a strange sound from the outboard. I look back and it's dangling in the water again! I struggled and was able to flag down a jet skiier for help. 30 minutes and a scratch on his gelcoat later we manage to get the thing on board. I take a couple minutes to rest and started the inboard. Oh how much quieter it was ...and then it got really quiet. I tried starting it up again with no luck. I deployed the anchor. We had drifted into the main entrance of the port but we were safe.
We called for a tow and enjoyed the water and sunshine while we waited. A TowBoatUS boat showed up a couple hours later piloted by two very nice and knowledgable gentlemen. They tied up to us and off we went. An hour into our tow we found water above the floorboards. I don't remember if our electric bilge pump was working or not but the manual one was up to the task.
They towed us all the way down the river. They instructed us that they would let out a ton of line and we would glide into our slip. Because of the water that had come in to the boat, we asked to be towed to the boat ramps across the river. They gave us a ride back to our slip to get our truck so that we could haul out.
It was dusk by this point. We hooked up the trailer and started to pull the boat up by the bow. The new but undersized winch was clearly starting to bend but eventually we got the boat loaded. I slowly pull the boat and trailer out and then my tires started to spin. For the next hour we tried everything under the sun to get up the ramp. Eventually we ask another boater if he could help pull us out. The guy, his friends and the marina guard all sprung into action while I was holding my foot on the brake so I didn't slide back. We had a line connected between the two trucks. We were ready to go. He hit the gas. I did the same and my engine just revved up with no movement. The line snapped. Embarresingly I had forgotten to put it in drive. Attempt number two was a success. The boat and trailer were out of the water. We profussely thanked everyone for their help.
We found a spot to park the boat and trailer along the edge of the grass. I backed it up and unlocked the hitch. The trailer tongue went flying in the air. It was 4' off the ground. The only thing that kept it from going higher were the safety chains that were still connected to the truck. We tried everything from the two of us putting all our weight on it, to ratchet straps to blocking the trailer tires while moving the truck forward. Eventually I grabbed my spare tire jack on the back of the trailer and left it at the marina. Exhausted from day number left for Chicago. We didn't get back till 2am.
And you're still married to the same woman? Solo sailor, now? :beer:
  • Ha
Likes: Indysailor
Sep 24, 2018
4,805
Three sailboats later, we're still together! There's now a dinghy, two kayaks and a neglected motor boat but we still have all of those
The rudder actually hit the grass when the trailer tongue went up in the air. That incident lead to nearly losing a rudder in a storm a couple years later when the the 1/4" steel lower gudgeon was torn apart. I think that's a testament to the strength of fiberglass. We didn't know about the damage until we went out a few days later and the tiller felt funny
