Holes
Hi Don:I saw your second photo of this posting of hte port gunwhale up forward. It certainly looks as if the hull-deck joint is damaged and in need or re-building. How far does that vertical crack in the hull go down? I'd pay close attention to that!It looks like a large enough repair to warrant having it looked at by a professional fiberglass repair shop or boat yard at least to get an idea of what it will cost. They will probably cut out what's damaged back to the original hull, and start from there with a hull and deck patch. The hull may have to be repainted as well.If the same unfortunate occurance where to befall me, I'd look into getting the work repaired professionally by a yard somewhere. Fortunatley it occurs in a spot on the hull where the stresses from the shrouds are minimal.The mast postings cauhgt me as far as how cheap the raw extrusion is ($400). The link I posted before for a new mast was off this site and (I presume) was from D & R. They quoted a 25 foot mast (fully rigged with spreaders, mast head fitting, bottom plate, and cleats for around $1200 I think.Up for a challenge and have loads of free time?Get the Dwyer mast section and shop around for the parts and custom-design your mast!Let us know how your work goes. Good Luck!Regards,Stu Timm"Karakahl"1979 O'day 22 CBCenterport
