Don Guillette
The Four elements Of Sail Trim To take the mystery out of sail trim is to essentially understand that all the controls for the mainsail and jib only adjust four things and they are: Draft Depth (belly) Draft Position Twist Angle Of Attack Lets start with the first two elements. Why do we have to understand Draft Depth (belly) and Draft Position ? We have to understand them because they control three things - POWER, ACCERERATION and DRAG. Drag, is actually friction, which detracts from power and comes from the rudder, keel etc. A sail is like an airplane wing and if a plane flew sideways it would be called a sailboat. The plane's flaps, in the up or down position , produce a deep shape ( like a belly) and are used for takeoffs and landings. No flaps or a flat wing create less drag and are used for high speed and cruising. Where does the POWER to power a sailboat come from? It comes from three things and they are the SHAPE of the sail, which is either deep or flat. The power also comes from TWIST. Twist is the most important sail trim adjustment you can make. I'll go into the definition of twist in a later message. The final element of power is the ANGLE OF ATTACK and I'll go into the that definition later also. What is DRAFT DEPTH (belly)? It is " the % of sail width at a given point". To understand that definition we have to discuss DRAFT POSITION, which is " the point along the chord where the maximum depth falls". To find the chord you measure the foot of the sail and mark the halfway point on the boom. In other words, if the chord is 10' long then the 5' mark would equal 50%. The 4' mark would equal 40% and so on. So, if the belly of the sail was 1' deep then the draft depth would be 10%, which is a relatively flat sail. If the belly was 2' deep then the draft depth would be 20%. Now, you have to imagine a vertical line going up the middle of the belly of the sail. Where that imaginary line intersects the boom is called the draft position. Assume the skipper of the boat decided that the point of sail and wind condition he was sailing in would need a 20% draft depth and a 50% draft position to obtain 100% efficiency from his mainsail. You know what setting you have to obtain and that is a 2' belly with the imaginary line falling at the halfway point on the chord line. You may not know what controls to use or which way to trim them but we'll get into that later. It is very important that you understand draft depth and draft position before we go any further. Any questions on the above two items?
