The flimsy 192 rudder headstock
2,500
Oday 192 Lake Nockamixon
So, back to an earlier post about the rudder headstock on the 192 (and I assume 222) being awfully flimsy.
Last night, I was motoring in, and I look back, and the headstock looks like it's got a curve to port in it. I was like, "Crap! Somehow I've bent my headstock!" But back in the slip, the headstock seemed straight. I theorize that turbulent flow outside the prop diameter was pushing the rudder blade to port, and flexing the headstock.
Now, I know that the headstock plates on my 15' Harpoon are about twice as thick as on this 192, and that's by far a smaller, lighter boat. And this thinner headstock gave me pause this spring when I was painting it. Now, I've seen evidence that it has woefully inadequate scantlings.
Has anyone else rebuilt or reinforced the headstock plates? If so, have you got pictures?
I figure the headstock needs at least 1/8" thicker aluminum plate. I was wondering if I could rivet plates onto the existing? Maybe cut it smaller than the inside of the stand-off spacer rivets? Or would it be better to find a machine shop that could fab me a new one out of thicker AL plate?
Thanks for the opinions and experiences...
Brian
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
I remember Rudy telling me about the rudder heads on some of the O'Days being made thin and flimsy. Fortunately, my rudder head came through with 1/4" aluminum.
What I would do is use your rudder head for a pattern and have a new one made. I would cut the new one out so that it extends a little higher over the transom. This way, you could mount a larger diameter tiller on it similar to what I have on my rudder head.
142
Oday 222 USA
Brian:
If it wasn't originally built that way, the PO of my 222 must have layered the aluminum plate over the top half of the metal headstock- about 3/16 to 1/4 inch thickness added. Until I read your post, I hadn't paid attention to the layered aluminum plate- as I haven't noted any flimsiness with the headstock.
2,500
Thanks, guys!
Mich, it looks as if the spacer rivets have been drilled out, and a SS bolt with nylock nut used in place of the rivets. Is that correct? It looks like a solid fix...
Perhaps this winter, I will disassemble and rebuild it with new, thicker side plates. I figure, if I'm going to mark out and cut (2) half sized pieces, I might as well cut out (2) full sized pieces! I'm sure I'll be able to spread the pintle brackets enough to fit on some thicker side plates...
I will look at mine very closely this weekend, to start formulating my plan of attack...
Brian
Nov 9, 2012
2,500
Hmmm, on further review of Mich's first picture, it looks as if the PO even added a block of hardwood up the aft edge of the headstock, in place of the spacers, for even greater rigidity. Now I understand the 1/2 size sister plate that comes up above the level of the foil head - because the hardwood spacer can't go down further than the foil head, so the side plate is sistered above the foil head.
Hmmm... food for thought....
Brian
Jan 24, 2005
4,881
Brian,
My rudder head also has a long Teak block on the front as well as the back of the head.
Joe
Nov 9, 2012
2,500
Hmmm... It's starting to look as if I have the flimsy version for sure. Thin plates, no teak spacers... I'm going to have a look tonight at some of the other 192s on my dock (there are 2 or three others. And several more in the marina...)
A rebuild like Mich's won't be difficult...
Brian
