The Difference Between Yachting and Boating
3,562
Endeavour 32 Portland, Maine
Well, maybe this isn’t really but I’m too tired from a day of buffing and sanding to think of a better title. It’s the difference between something and something though.
I had the boat hauled last Monday with the plan being to jump in the car and drive out to upstate New York just minutes after it was set up on the blocks and secure. Just before the haul, I got to thinking about all the complications that have kept me in Portland far longer than planned, what a week cruising in Maine is worth, and decided to ask what it would cost to have the boat buffed and waxed while I was gone so I could just slap a coat of paint on the bottom and leave after my return.
There were three deep chips in the transom corner where the towing eye of the dinghy had hit just wrong before I figured out a different knot that provides some protection from the towing eye. These were right down to the raw glass so would need to be repaired before wax got into the hole. I had the service manager come down to look at the boat and told him I had repaired these before and found that JB WaterWeld epoxy putty is an almost perfect match for the gel coat on my boat.
“Our minimum charge for a gel coat repair is $400.”
Oh, this is going to be a much shorter conversation than I expected., I thought.
So, after a little more polite breeze shooting, the boat was hauled and I headed off to spend three days helping re-roof a cottage. That involved sheathing the old boards with 1/2 inch plywood which my 89 year old father and I loaded in the pick up truck. Horsing that stuff around and up on to the roof and all the other activity, including falling off the ladder directly on to my hip, seemed like the perfect storm for the problems I’ve been having with the back / hip joint but it had to be done. I returned, did a day of easy projects on the boat and then today’s buffing and more running up and down ladders. I feel great. I think I’m going to cancel my appointment with the back doctor. Being more consistent about my exercising and stretching seems to have done the trick. I’d feel pretty silly talking to a doctor after a week like this with no sign of pain.
I told you I was tired, I’m rambling. Anyway….
Fifty cents worth of the JB Weld went on the three dings in about three minutes. It’s moisture tolerant so I went back ten minutes later after it was half cured and ran a wet finger over it to smooth it up a bit. An hour later, 30 seconds of sanding with 600 wet/dry paper took care of a couple little rough spots. Here is one ding showing the result of less than a dollar of material and less than ten minutes work.
It’s just to the right of my finger. I can hardly find it on the boat either. $399.50 ahead.
trasel
Dec 26, 2011
56
Endeavour 32 Middle River, Md.
Roger, relieved to hear that your back is feeling better and good going on your gel-coat repair, it looks great.
May 24, 2004
470
Hunter 33.5 Portsmouth, RI
Ask the yard if they will sub-contract small gel coat repairs to you for half of the $400 yhey charge. You can net $199.50 on each such job.
Pearson 26W Marblehead
Question for Roger Long or anyone Else with an Idea
Roger just commented about picking up some putty for a small repair. I had my boat al gripped last season On a breezy day recently a jib sheet slap on a tack caused some small paint damage on a bulkhead.
I called the yard that did the work to get some touch up paint. The Manager said he was all out and told me, go to West Marine for touch up paint. I asked what color He didnt know or care Its an off white. I know there are at least 25 shades of off white Anyone have any Ideas.
Bob Fox
Sep 17, 2012
74
Oday Mariner Middle River Md
Re: Question for Roger Long or anyone Else with an Idea
Bob,
I had a similar issue with an "off-white". I happened to be in an "Ace Hardware" and they had about 50 paint cards for off-white. I took one of each which they didn't mind, [and returned the ones I didn't use] then used the matching card to "shoot" the color in the paint type I wanted. It came out spot on.
robj
May 24, 2004
7,226
CC 30 South Florida
Don't worry, things tend to even out. The day will come when when you work your butt off and spend big bucks in tools, parts and materials to complete a job that would have costed half the amount to have someone else do it. So save the $399.50 for such a day.
