E
Ernie Tetrault
Gordon- You are a bonified vacation saver!! I tried your suggestion of checking the fuel line before the feed pump, and sure enough! There was a loose connection on the newly installed Racor. After correcting the problem, she ran fine for five hours at a time instead of five minutes.( Not much wind available this week.)I do have a couple of other questions:1. Since the 2QM15 is raw water cooled, it isn't set up to work with the heat exchanger in the ship's water heater. Is the stock water pump "gutsy" enough to handle the additional run to and through a heat exchanger? Is it possible (and workable) to add on an alternative water pump?2. I installed a Teleflex water temprature gauge and sending unit. I have been round and round with Teleflex (they even gave me a new sender unit) but I can't seem to get it to read any temprature. I have thouroghly checked and rechecked all connections, but still nothing. My only near-rational explanation is that the raw water going through the system doesn't get warm enough to register. Can you think of anything else to check or do?3. Finally, I have noticed that almost all instructions I've seen for bleeding the engine's fuel system refer to shutting off the water intake. Why is this?Thank you for all of your fantastic help!!!Ernie
