Okay, according to the instructions that came with my new Loos 91 tension gauge, the shrouds should be adjusted to 20% of the breaking strength of the cable. That's approximately 700 lbs for 5/32" cable!So I was out on the boat today checking my shrouds. The weren't even close to this tension! I started tightening them and on the first lower shroud the handle on the rig tuning tool I bought from Blue Water Yachts split completely and one of the pins/bolts was bent.This rigging tool from BWY obviously wasn't designed for this kind of tension. This makes me wonder if the Loos instructions are applicable to a Mac even though they describe our setup exactly. (see quotes below). I plan to call BWY Monday, I was just wondering what your thoughts were. One important point: I don't trailer mine so I don't care for ease of mast lowering and raising. I'm looking for the best performance."Upper and Lower Shroud Tension - Fractional Rig: For most fractional rigs the correct shroud tension is the same as that for a masthead rig, i.e., a tension setting that will keep the leeward shrouds from going slack. However there is one exception. On certain fractional rigs , the upper and lower shrouds lead to chainplates that are aft of the mast. The spreader is swept back. For such a rig most of the forestay tension is balanced by the upper shrouds. A shroud tension of approximately 20 % of the cable strength may be required to achieve the desired forestay tension. Never exceed 25% of the cable breaking strength. (Refer to the breaking strength chart Table 1.)"
