Tension, tension, tension...
gary
Jun 5, 2004
86
- - Sally Rose
This is directed at Crazy Dave, but anyone with an answer is welcome.
I am trying to find the manufactures specs for tuning the standing rigging on my Hunter 22. Would Hunter have these? If you think so who should I contact?
Thanx
Kermit
Jul 31, 2010
5,722
I've seen Dave tension shrouds. He has his own system that doesn't involve a Loos gauge or numbers. He just know how far they should pull when pulled upon. I hope he'll respond.
Jun 6, 2006
6,990
You should try the "boat info"/ 22 / downloads / rigging file on this site.
Jun 3, 2004
134
Hunter 23.5 Cape Cod, Ma.
I tune my H23.5 fractional rig with a Loos gauge that I bought at West Marine.
It gives consistent,accurate readings if you follow the directions.
The objective is to have a mast that is straight side to side, with the forestay and shrouds tensioned, so that when sailing close hauled in a brisk wind, the lee shrouds are tensioned and not loose. I use the method described in the manual first and then proceed to tension the forestay and then the port and starboard shrouds EVENLY, a little at a time , using the gauge, and then test the results on the water. Much better than guessing the tension by "feel".
Here is alink to the directions.
http://loosnaples.com/files/PDF/INST-02.pdf
-na -NA Anywhere USA
lGary;
Contact me thru davecondon@mindspring.com with phone number and location. I will give you a call sir and go over my approach which worked well for me tuning small to large boats as taught by the old timer sail riggers and a few who use to tune some of the America Cup boats.
