Tension Specs for Beneteau 323 standing rigging
Nov 5, 2015
11
Beneteau 323 Punta Gorda, FL
Anyone know where to find tension specs for Beneteau 323 backstays? I check the manual, no luck.
The manual probably won't say the tension, but it should say the diameter of the wire. There are then standards to determine tension as a percentage of breaking strength for that size wire. (15% is pretty typical)
Nov 5, 2015
11
Thanks! I'll look up the spec for 3/16" Cable
