H
HAL
How much drag would you say an 8’ inflatable being towed at 4 knots creates? There is quite a bit of tension on the tow line at this speed. Would it take off as much as a knot ,or more like 1/4 or a 1/2 knot?
But the extra person in the dink will affect the drag. You need a shadow boat to pick up the dink when it goes adrift.I think that a lot of these questions can be answered with a spring scale and an adjustable painter on the dink. Tow the dink at various speeds and distances from the mother boat and record the boat speed and the load on the scale. Then with someone in the dink tow it at speed and set it adrift and note the speed change. Then don't forget to go back for the dink and its crew. ;D
