When I install my new Temperature sender in the thermostat housing I get a false reading on the gauge pegged at 250 degrees. It is false. The thermostat works.
I took the thermostat out and the gauge reads 150, too cool for the Great Lakes. The thermostat works perfectly, confirmed in a pot of hot water at 160 degrees.
I've decided to install the sender elsewhere in the block, 'cause I know there's a square headed threaded bolt there somewhere, but for the life of me it is not showing itself, nor in the manual. Help?
Thanks
Thanks
