Adding guages
It is posible, but I don't recomend it.THe coolant sending unit will need to be removed and a "T" placed, then a sending unit for the guage added. The location of the temp sender is ok, but most of the nipples out there are brass and will crack under the vibration.I won't do this for an oil pressure guage, when asked. The oil pressure switch is to close to the belts, and when a "T" and nipple are added you will run into interferance issues. Otherwise, if you want to do this the threads are pipe thread and any guage from the auto parts store or West will work.Pat McCartinInland Marine DieselBuford, Gaimd_ga@hotmail.com
