Would like to add a dual audio alarm (Oil Pressure and Temp) to my 1984 Catalina 30. Need advise in "How To" department.
Calif. Ted, thanks for the link. I called tech support as suggested in the link. My engine, the 5411 can't use the kit mentioned in the link, but I will keep looking. Again, thanks.This webpage from CD may be helpful to you to start the retrofit on your engine.
http://www.catalinadirect.com/index.cfm/feature/153/engine-warning-alarm-system.cfm
Thanks for your post. According to my readings, pre-1990 Catalinas did not come with these audio alarms.i'm confused by your word 'add.' didn't you boat come with a seaward products panel with these alarms buillt in? if they are missing, seaward is still in business in california and a very helpful company. forget catalina direct.
My 1986 C34 certainly did. No reason to believe that C30s with the same engine didn't.Thanks for your post. According to my readings, pre-1990 Catalinas did not come with these audio alarms.
