Mates: I have to do this in sections because the subject is too long for this format. It is probably better that way because there is a poop load of stuff to absorb and we can hit any questions that come up as we go along. POINT OF INFORMATION: All of the following is designed for the beginner to intermediate (my favorite kind of sailors). Experts will probably be bored to death.What are telltales telling you anyway? They are telling you if the flow of air over the sails is attached or not. Why do you care if the air is attached or not? The reason is that if the air is not attached equally to both sides of the sail, the sail will stallas it no longer is efficient. Picture your sails in a wind tunnel with smoke blowing over them. That is the effect your looking for. It is called "attached flow" . The technical name is "stagnation streamline".What we want is the leading edge of the mainsail and jib to be aimed DIRECTLY into the wind. The telltales on both sails will tell us if we have achieved that objective. Telltales will react to the stream of air and tell you whether the flow is smooth or turbulent. You can see this in action by first getting all the telltales on the main and jib streaming back and then ease or trim the mainsheet and jib sheet. Watch what happens. The telltales will react because the sail is no longer pointed directly into the wind. By conducting this simple exercise, it teaches you exactly what adjustment you have to make or what trimming instructions you have to give to the trimmer to get the telltales streaming again. As you can see so far, this is not brain surgery. So, if your sailing along and everything is going nicely and the wind changes direction and start hitting the windward side of the sail, what will happen? The flow of air will become separated or not attached and the windward telltale starts jumping all over the place. Same thing happens if the wind hits the leeward side.Suppose the telltales on both side start jumping all over the place? What is that telling you? It is telling you that the flow is to turbelent on both sides and an adjustment must be made quickly or soon one side telltale will hang limp. What that means is the sail has just stalled and your going to be slowing down.So what exactly are we looking for? We want the jib telltales to both be streaming, especially the middle ones. We want the mainsail to be streaming, especially the top ones and the ones in the middle of the sail. Any questions so far? Next we'll talk about how you tell whether your sailing to high and pinching or too low and footing.
