Teflon tape is the ONLY thing to use.
And it will not crack fittings. However, overtightening them will crack a tank. Tighten plastic fittings NO MORE THAN a full turn past hand-tight, plus enough to aim an elbow in the direction it needs to go, even if threads are still showing. Test the tank for leaks...if it's leaking, back the fitting out and wrap with teflon tape. Do not use silicone...silicone only fills space--it doesn't seal a thing...and it WILL dry out and crack (the silicon itself, not the fitting)...above all, don't use any sealant such as 5200...you'll never get the fitting out again when you need to rehose. The only thing to use on plastic--or any other--fitting is teflon tape...and only if needed.
