Teak Substitute
218
Catalina 30 Mark I Stockton, Mo
I tried searching, but didn't find anything. I need to build a radio rack/electric panel box, and I want to make it out of mahogany. I read somewhere that I could use mahogany and stain it to look like teak. Two questions: which teak, and what stain?
Any advice would be greatly welcomed.
Thanks,
Mike
Fed up w/ personal attacks I'm done with SBO
Mike,
I see your question has fallen on deaf ears so I'll give it a try. What follows is my warped view:
1. I resist trying to make something into something it's not. Mahogany is not teak, never will be. You can make a monkey wear a tie but it's still a monkey. For me, I'd spring for the teak. If I only needed a little, I'd canvass the dock and elsewhere to see if anyone else can use the offall, maybe share the cost.
2. Moving away from that position, there are some popular substitutes. Sapele and Afromosia come to mind. They'll cost less than half the price but may be harder to find than teak.
3. I've never found the substitutes in plywood, only solid stock.
4. Afromosia is readily available at Strata Forest Products in Santa Ana, CA but "I don't think we're in Kansas anymore." Shipping would likely drive the cost up into the teak neighborhood and you're right back where you started.
How soon do you need the wood? I've got a project in the planning phase that will use maybe a half sheet of AA teak plywood, would be interested in moving the rest along. Have the ability to cut to size as well.
Interested?
Jul 7, 2009
218
I appreciate your help. Seems like any time I post anything lately, no one takes the time to answer...maybe my questions are too hard.
I need to start building my radio rack some time soon. I plan on spending part of the winter in the boat re-wiring, and this rack will house not only the radio, but my electrical panel, A B switch, gages, etc.
If you have any drop, I would be interested in a couple of pieces that are maybe 24 X 12" or so. Let me know if that sounds doable. Ply would work for me...I can miter the corners to hide the sandwich construction.
Thanks, Neil!
OK Mike - and anyone else who may be interested.
My project will leave the following sizes of 1/2" A-3 (good on 1 side) teak plywood available:
grain runs the length dimension
1 pc 6"W x 38"L
1 pc 18"W x 19"L
1 pc 48"W x 39"L
Actual dimensions are slightly under - by the width of one saw kerf.
