Teak seats
DClark
-Beneteau -351 Newport,RI
I have a Oceanis 351 with teak seats and it appears that the port side teak is not fully glued down. When it rained last week I could push down on the teak and some water would come out. The seat is fine and not worn, but have othere seen this and what is the fix? Thanks Dave Newport,RI
Jun 1, 2004
227
Beneteau 393 Newport
Lift the panel
and inject some glue under the panel, put some weight on it and let it set. Your problem should be solved.
Mar 2, 2006
11
Beneteau First 33.7 Gosford, Australia
Sikaflex ......
.... is what most of us here use to fix that problem. Works a treat.
