Teak seat covers in cockpit
Jan 10, 2018
264
Beneteau 331 Halifax
Hi there, what have you used for the black stripping both around the perimeter and inside to seal these against the weather?
Thanks,
Mike Casey
Halifax, Nova Scotia, Canada
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
I have used black Boatlife caulk.
Strip out and clean the old caulking.
In the process, I completely removed the teak panel, cleaned the fiberglass surface as well as the bottom of the teak. I glued the seat surface down with a high quality construction adhesive and weighted it down overnight.
To caulk the perimeter, I masked both the wood and fiberglass sides of the ditch then carefully applied a bead of caulking.
Jan 10, 2018
264
I looks like I'll have to peel a couple off. When you do, does the individual slats of teak come apart?
SG
Feb 11, 2017
1,670
J/Boat J/160 Annapolis
Not likely. The caulk is usually just intended to keep water from penetrating below the surface. The "boards" are held down by adhesive and/or screws. If the boards are loose, then you have different issues to deal with.
In case you're new to this, when you clean the teak, gentle is better than remoing a bunch of the cellulose that binds the wood together. Once it's gone, you have top sand down the teak or live with the "ripple effect; or, replace it.
