Randy
I'll be re-installing my exterior teak trim...Should the teak plugs covering the screws be installed with an adhesive or glue, or should they be dipped in the teak finish (in my case, Cetol Light), and then inserted? The old ones I drilled out had a dab of silicone underneath, which had to be cleaned out of the screw head before the screw could be backed out.Randy
