Teak Oil (interior use) recommendation
Bob
I do not have a report from Practical Sailor to get their test results so I have to rely on a concensus from my fellow sailors on what works best for a teak interior. I have a 1988 Catalina 30, that has an interior is just about all teak, some solid, some veneers, BUT nothing varnished or poly-coated. Teak shelving, teak bulkheads, teak cabinets, drawers, trim, etc, etc.... Years ago I came across, Tip-Top-Teak which was a fairly dark blend of oil that seemed to penetrate well with little remaining residue. My West Marine stores do not carry it any longer and I am willing to try something new. I am seeking a wipe on oil type penetraint that is not intended to be a sealer or leave a poly type coating. The wood thoughout the interior is not dried out, cracked or treated. If anyone can recommned a good teal oil that has provided good penetration, longevity and appearance, please chime in. I would like to know what everyone uses and may well recommend for interior use. Thank you Bob Breezin II
Feb 4, 2005
524
Catalina C-30 Mattituck, NY
I would not use oil for interior
Bob - I teak-oiled my interior Catalina 30 and was not pleased with the results. Teak oil holds dust and does not seal the wood off from any moisture which leads to mold, mildew and odors. I would instead research some varnish or similar types of finishes. 1-2 coats is all you need as you will not deal with the same issues you have for exterior wood (sun, wheather, etc). I used Cetol on my interior and the boat looks, smells and stays amazing pleasant! Good luck - Rob
Dec 25, 2000
5,951
Hi Bob, when we purchased our 1991 boat in...
2002 it had some mold on the wood surfaces, but not much. I use regular teak oil from WM on a rag to clean up and refurbish the interior. I'm very pleased with the results, no mold since and the wood still looks like new. Each season I will do touch up on areas that appear to have lost the teak luster. I, too prefer not to use any kind of sealer or finish other than on the sole for wear and tear. Terry
CalebD
Jun 27, 2006
1,479
Tartan 27' 1967 Nyack, NY
While I love the look of oiled teak
I know that it only lasts a few weeks on my exterior teak unless I cover it with a good exterior marine varnish. I too have a fair amount of interior teak on my old Tartan 27' (1967) but it was varnished when I bought the boat 4 years ago. The original varnish has held up amazingly well with no maintenance required. That said, if you oil the interior then be prepared to maintain it fairly regularly. My suggestion would be to oil the interior teak as you planned to and let it soak in for a few weeks. Then wipe it down with acetone to remove excess oil and dust and then put a few light coats of the varnish of your choice to seal it. If you really hate the gloss of varnish consider using a Tung oil varnish that will seal the wood but does not build up a thick coat of gloss until you put on many coats. This kind of varnish may not hold up as well in a marine environment as products designed for it.
Ross
Jun 15, 2004
14,693
Try Watco. I have used it for years on any
wood that I didn't want to paint or varnish inside or outside. It dries hard and not at all sticky just don't leave any puddles.
jeff s
1985 ofday anniversary 26 ftr
I agree with Ross,I have been using Watco for years on this boat and it had been neglected when I bought her. After a few years it looks pretty good,I do it every year prior to putting the boat in for the season.
Feb 6, 1998
11,723
Weimans Lemon Oil...
I have had very, very good luck with Weimans Lemon Oil for interior teak and it can be found here: http://www.weiman.com/products/furniture/lemon_sunscreen.php It smells nice , contains no silicones or waxes, naturally resists mold and cleans the wood as you apply it. It really really works quite well giving a nice satin look! -Maine Sail Sailing Photography by Maine Sail http://www.pbase.com/mainecruising
Sep 15, 2006
202
Oday 27 Nova Scotia
Deft Marine Teak Oil-natural finish
I've had great results with this product, both on the boat and on teak furniture at home. Used as per the directions on the can it dries hard & doesn't darken the wood appreciably. There's no oily feel to the wood after a few days and additional coats can be added as needed over time, without the hassles that recoating varnish entails. Google 'Deftoil' if you can't find it in a local outlet.
Grizz
Jan 13, 2006
179
Hunter 28.5 Park Ridge, IL
Rite of spring?
Not that it's an election, but I too vote/opt for the teak oil treatment. Preferably pre-splash, before the cushions and other accumulated 'gak' is stowed and after the interior has been given a wash and clean, we give the teak surfaces a wipe and rejuvination. Looks good, smells good and serves as a declaraton that the boat is ready for the 6-month season.
Mark Juetten
Fornbys Lemon Oil
Have used Fornby's lemon oil for about 15 years. No build up, does not stain FG and smells great. Apply liberaly and wipe off excess. Last all season. do it again in the fall.
Feb 12, 2007
259
Ericson 25 Oshkosh, WI
Sweet
Steph- Sweet looking interior. I will definantly consider Amazon on my interior woods. I do love Starbright Tropical Teak Sealer, for all my exterior teak. Rob Hessenius
Feb 6, 1998
11,723
Be Careful With Some Oils...
Many of these oils contain silicone! Formby's lemon oil is one that I think does! When I was searching for a lemon oil, without silicone, I actually called the manufacturer and they would not disclose their "secret ingredients" except to say that if you ever plan on re-finishing not to use their, Formby's, lemon oil.... That to me says it has silicone in it. If you NEVER plan on re-finishing your interior wood or varnishing it than a silicone based oil is ok, still not prefreed, but ok. But if you ever need to touch anything up DON'T use anything containing silicone as NOTHING will stick to it. Even some of the cheap teak oils contain silicone...
Liam
Apr 5, 2005
241
Beneteau 331 Santa Cruz
Pledge Wipes
Pledge makes a disposable lemon oil wipe. They come in a re-sealable zip-lock container. Super easy to use. Buy them at the grocery store.
Dec 2, 2003
480
Catalina C-320 Washington, NC
Here is the scoop.
The problem with teak oils today, is that the manufacturers have increased the proportion of thinner to keep the cost increases down. Any of them will work just fine. Poorer quality teak oil(i.e. more thinner) just takes more coats and drying time between coats to get a good finish. How do you tell which is best? Turn a bottle over quickly and watch the little bubbles rise. Faster bubbles = more thinner and more coats. Slower bubbles = less thinner and less coats. Don't buy teak oil in a can.
Bob
Choices!!!!!!!!!!!!
Its like chewing gum!!!! Everyone has their favorite flavor and brand, but its chewing gum!!!! I thought the Pledge wipes were the most interesting as well as good ole lemon oil. Interior teak, when protected from sunlight and moisture attack will keep its rich dark luster given all the treatments cited here. I guess its really what your comfortable with and used to. Years ago I swore it was "tip-Top-Teak despite being packaged in a can. I greatly appreciate the responses and all the recommendations. Its simply a spin of the wheel here. Bob Breezin II
