Teak Maintenance
Bill Drent
I recently purchased a Catalina 22 on which the teak trim is badly aged, and I want to restore it. When I visit boat stores I see a large variety of products and proposed techniques, and wonder if any of you have a method that has proven to be superior over time. Cetol was recommended to me, but when I applied it to a small test area it turned the teak very dark -- almost black, so it is obvious that some prep work is needed. Any advice would be appreciated...
C
Chris Burti
Whew!
Lots of territory to cover and lots of divergent and yet valid opinions. Here is a brief synopsis. If this is a troll...I'm had. First task is to prep the teak. Note that, "badly weathered" can cover a range of ills. If merely grey and dirty; clean and bleach out stains with ZUD or Barkeeper' Friend, lots of water and a soft bristle brush. These products contain oxalic acid, a wood bleach that won't harm the wood fibers. They are a lot less expensive than teak cleaners and almost as effective. A stiff brush will gouge out the soft fibers between the ringwood in the grain, so it is a major no-no. If the weathering has 'raised the grain' (it is the reverse in actuality), you will need to sand the teak and bleaching may still be needed afterward if the staining is deep. Then seal with your choice of sealer...varnish (a generic term for hard glossy finishes), polyeurethane, oil or even Cetol. Some of the new two part varnishes (such as Honey Teak) are extremely tough, easy to apply and long lasting. Cetol has an excellent reputation for durability and ease of application but some find that it colors the wood an objectionable shade.
Bill Drent
Thanks...
Thanks, Chris, for your advice. I don't know what a "troll" is in the sense you use the term, but presume it means someone looking to sell something? In any case, it was a sincere question. As you can tell, I am new to sailboat maintenance...
Mike
Teak Re-finishing
Hey there, I have a catalina 22 as well, and when I first got her, the wood was really nasty looking. It was dark in areas, grey in others and the grain was slightly raised. I removed all the wood from the boat, this is very easy. I sanded the wood first to smooth it out. Then I used the starbrite products, teak cleaner and teak brightner with a soft brush. Let it dry thourougly, then vaccum it with one of those attachments with the brush on the end. This will remove any left over dust and debris from the grain of the wood. I then used the regular Cetol product. It is awesome as far as durablity and I personally like light-orangy color it gives the wood. Use 4 coats, then sand lightly with steel wool, and apply one more coat. I think you will like the results. The regular Cetol has shiny, yet satiny finish. It is a light orangy color. The Cetol light has the same finish, but with a less orangy color once its dry. There is also a Cetol Gloss finish that you can apply to your Teak after you have applied a base coat or two of the standard cetol. With all this hype for Cetol, you'd think I work for Sikkens or own a of share the company, but this stuff really works. I've seen it on other boats and it lasts for years without a re-coat.
C
Chris Burti
Grin
Nothing derogatory intended toward you. Ask all the questions you like. You'll find a lot of good friendly advice on this forum. I was just poking a little tongue-in-cheek fun at myself since I seem to have been jumping in to a lot of discussions lately. Best regards, Chris
