Jeff
Areas of my original veneer teak-holly floor on my '82 33' Cheribini have begun to to delaminate, probably due to a period of standing water below, because of a faulty bilge pump with the prior owner.The flooring is solid underneath the veneer, but very thin layers of the top are peeling or flaking off at the edges. The flooring looks to be 3/8 inch marine plywood with a teak-holly veneer. I plan on replacing with similar material and would like to know whether anyone has simply glued and screwed new flooring down over the old ?Anyone with a 33' knows that the cuts would be simple, and all sections lay on top of the fiberglas framework with no bulkheads or cabinets sitting on top of the flooring.What say you ???
