Teak Handrail Bedding
Oct 27, 2024
16
Hunter 27-2 Rogersville
I am in the process of replacing the badly weathered teak handrails on my 1989 Hunter 27. When the time comes to install them, do I "bed" them with sealant at the contact points with the cabin top, or is there something more specific I should be using?
Mar 27, 2024
8
Hunter 39 Wickford
You should bed them. For no other reason than you want to make sure the fastening holes are sealed. I've used life caulk in teak color for this in the past. I'm sure there are multiple different products that will work.
  • Helpful
Likes: ggrizzard
Oct 27, 2024
16
Bed-it seems to come in 1/2" wide tape. Would I lay two (or more) strips side-by-side then tighten the rail down? Would I expect it squeeze out as it tightened? I remember a roll of this stuff in my dad's garage for the windows in our van. Seems like a forever solution.
No. Never do that. What you should do is roll it up into a ball, and heat it with your hands, and only then flatten it out and place the appropriated amount under each rail before you tighten the nuts&bolts.
