I believe that Oxalic acid is the main component
of the commercially available teak cleaner. If you buy this stuff the application directions are on the bottle but it is basiically this: manually clean teak (sand paper), apply solution, let sit for a period of time, rinse off, let dry, repeat, etc.Both Don Casey and Higgs recommend using a bleach solution and is probably something you would have easily on hand so why not try that first?Here are some of Don Casey's comments from the link above (in case you did not read it):CleaningBefore teak can be given any coating, it must be completely clean. Your expensive teak is literally dissolved by strong cleaners, so always use the mildest cleaner that does the job. A 75/25 mixture of liquid laundry detergent (such as Wisk) and chlorine bleach may be adequate, perhaps boosted with TSP (trisodium phosphate). Apply this mixture with a stiff brush, scrubbing lightly with the grain. Leave it on the wood for several minutes to give the detergent time to suspend the dirt and the bleach time to lighten the wood, then rinse the wood thoroughly, brushing it to clear the grain.If the teak is still dark or stained when it dries, a cleaner with oxalic acid is required. This is the active ingredient in most single-part teak cleaners. Wet the teak and sprinkle on the cleaner. Spread it evenly with a Scotchbrite or bronze wool pad, then give it a few minutes to work. While the wood is still wet, scrub it with the Scotchbrite pad or bronze wool. (Never, ever, ever use steel wool aboard your boat-it will leave a trail of rust freckles that will be impossible to remove.) Oxalic acid will dull paint and fiberglass and damage anodized aluminum, so wet down surrounding surfaces before you start and keep them free of the cleaner. Rinse the scrubbed wood thoroughly-brushing is required-and let it dry completely.There is a lot of information on teak finishing/restoring out on the web if you have the patience to do a Google search or two and sift through the results. Good luck.
