What type of boat do you have?
Cliff:What type of boat do you have? If it is a Hunter, you can call them. They even have some of the patterns in stock or can cut the for you. If it's not a Hunter you may try the customer service department of the Mfg to see if they can help. If none of the above are true, you should find out what are the measurements of the piece you need and also need to know the pattern of the teak/holly strips(width of holly and how far apart). Then you may call around to some of the boat yards or call H&L Marine in Southern California. They may have something in stock.
