Hit it from the port side. Our chairman, Mike Freeman, has just carried out
the
removal and replacement of the rudder and will be doing an article in the next
VAGB newsletter. I have also had some stainless steel tapered pins made
especially for the job. They are £5 each and I have eight left.
In a message dated 2/8/2004 2:53:48 PM Eastern Standard Time,
towlerg@... writes:
the answer is port - - Does this mean: A] Tap the port side or: B] The pin
comes out the port side?
I was so flushed with my actually achieving anything that I was not
thinking so well. Having hit both ends of the pin numerous times I
kinda lost track. I'm about 95% sure you hit it on the stb side. The
thing that makes me even more unsure is that the pin is badly bent,
so I can't even say for sure if it was fitted the right way when it
was last installed.
