Last night I replaced the tapered pin at the rudder head. It had
sheared. That part is available in the States from McMaster Carr in
Los Angeles. They are wholesale only so it may be necessary to go
through the boat yard. The part number is #90681A293 and described as
a #4 X 4" stainless tapered pin, .167" small end diameter, .250"
large end diameter. The taper is right but the pin is long and will
need to be cut short after being driven home. Perhaps this will save
someone from going through bins in the machine shop.
Craig
Craig
