Tap faucet knobs
Aug 4, 2013
12
Hunter 386 Comox
Help! Need to get hot tap faucet knob off the shower faucet on my 386 but can't work out how to do it. The tap is faulty, not allowing hot water out.
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
Pressure
How is the pressure at all the other faucets,I had very low pressure
at all my Hot water faucets.
The filter at the hot water Heater was clogged.
Nick
Dec 19, 2006
5,836
Handle
Should be a little red dot in the middle of handle and pop it off
and screw is behind it to remove the handle and than guts to be
cleaned or replaced.
When you get to the screw tap tap it with a screw driver and hammer,if it doesn't come off easy.
Nick
Aug 4, 2013
12
Hunter 386 Comox
Cheers all. Will look later. Meanwhile the clew just ripped off the mainsail. One of those days....
