Skipper
Hello Peggy,
I have a Snake River tank monitor on an 8 gallon holding tank.
The tank monitor display (5 led's) has gradually increased to 3 bars (1\2 full) over the last 2 years, even when the tank is supposedly empty.
Regardless if I use the macerator overboard discharge or pump out and rinse through deck pipe, the monitor still reads 1\2 full.
Whe I use the macerator (yes, 3m offshore) it take about 25-30 seconds to empty (pump noise changes to air bubble noise then winds up). I discharge a few uses after the monitor reaches 3\4. It has never reached "full". The macerator pump is rated at 12GPM max so am deducting that it pumps out between 5 and 6 gallons. This being the case it seems there may be something wrong with the monitor.
My questions are:
1. If this is a typical problem with monitoring systems, what could be wrong with the monitor and what is the remedy?
2. If the culprit is some kind of tank...ahem...buildup...how can the buildup be removed? I already rinse at the pumpout dock until clear water is visible during pumpout.
Thanks,
Skip
My questions are:
Thanks,
Skip
