Tank display panel replacement
Feb 23, 2024
3
hunter 36 36 Forked River NJ
Need to replace original tank system monitoring display for water/holding tank and can't find comparable display as original has been discontinued. 05 Hunter 36.
Dec 2, 1997
8,966
- - LIttle Rock
You actually need to replace that complete system with a current one that also uses sensors that attach to the outside of the tank. SCAD Tank monitors Scad Tank Monitors are top rated, inexpensive, available from many retailers including Amazon and easy to install if read and follow the instructions. SCAD also has excellent tech support.
--Peggie
  • Helpful
151
Hunter 356 SF Bay / Delta
