How good are you at following a chart...
Tampa Bay for the most part will accomodate a draft that deep. Be careful of the channels, and most inlets where there is constant shoaling. Do not cut corners on channel markers. I have done that a couple of times, you make it sometimes, sometimes you bump bottom. My boat only draws 3 feet, the keel is 2 1/2, but the rudder is 6" lower than the keel. So you feel the bottom in the tiller before the keel hits.I have the luxury of being able to put my shoulder to her and for the most part muscle her out of shallow water. You might not have that luxury.Just my 2 cents.Ross in Tampa1979 Oday 25 "Lola"
