Hey Stephen
S.I was surprised Janice had nothing at Sunrise for you. The new dock "J" looks like it has room in plenty of deep water. Across from us on "I" dock they sold an older Pearson Invicta (Snugharbor brokerage) and it should be heading down to Alabama soon. Sunrise has it over Aqualand by a mile, but at least you will have a dock in the interim. I would not think Lanier is getting lower with all this rain lately. As far as the survey, I personnally would dive on the boat to check the bottom for blisters, keel and rudder condition. Are you a scuba diver? If not, their must be some locals who know what to look for and blisters can be an issue, especially since they are more prevalent in fresh water. Catalina's are no less prone to osmotic blistering then any other production boat out there. Even barrier coats can be applied wrong and may not be effective. I am sure your on top of everything regarding the boat history, last haul and paint, etc. But, if you have the option in SC to haul and inspect, the few hundred bucks would be worth it and blister or bottom repair costs can be negotiated before transporting to Lanier. If their is no real damage or just moderate blistering, you can do the work in the Aqualand do-it-yourself yard when they bring the boat in. Its probably a great time anyways to wax the hull, fix any problems (cutlass bearing, add a zinc to the shaft, check rudder play, keel health, thru hull fittings, change spreader boots, replace light bulbs, add a wind indicator, lubricate shieves, inspect the standing rigging while the mast is down, etc, etc) and paint the bottom. The yards a fun experience and their are plenty of folks who can help or provide assistance. Let me know if you need any names. I have heard of a guy who is the "blister master" who will repair for a buck a blister!! I repaired over 600 on my last boat (Hunter 25.5) so I can get you going in the right direction if you want to fix them yourself. Lets hope the bottom is clean and all issues minimal. Good luck and congradulations.BobLake Lanier
