Skipper (Eric)
if you have not tried Start Brite's, Hull cleaner, give it a try! It is amazing. It will take off all the stain at the water line no matter how much or how old they are. Also, until you have put Star Brite's, Hull cleaner on your top side, you have not seen white yet!!!! You can bleach the top side all you want and it will not come perfectly white till you put this stuff on. Trust me! Also, try Star Brite Mildew remover. It takes mildew out instantly from all materials and does not discolor!! Both are sort of expensive. They both cost about 6 to 8 dollars depending on your location. But they are both well worth the money. You can delute the hull cleaner with 50 percent water, I have found, and it still works great and makes it go a whole lot farther. I don't know if you can delute the mold remover. If any one tries, please let me know!Your PalThe Skipper from Ohio ....Hunter 27 owner, Eric Stanson
