no probs
jeff,I have your exact boat, and have sailed from australia, to windward across the pacific, and down the west coast into the carib - 24000 miles over the past 18 months! and 2 handed.we have seen all sorts of weather, including 36 hours of 50 to 70 knots and 35 feet seas!i have been extremely impressed and happy with the performance of the boat, experiencing few problems, and i am certainly not concerned about the strength of the boat or the displacement. the boat is very stable.i would conssider a couple of things - the headsail turning blocks are not strongly anchored to the hull, and i got some fairly beefy aluminum plates made up and bolted through to these which in turn bolt through a strengtheniong crossstrut which you will find in the rope locker.i would also consider the same for the baby stay anchor point.i also put new rod rigging on the boat before we left.there is some concern with US built beneteaus as to hull strength and thickness i believe - the only problems i have encountered with other boats have been US built boats, but all the BVI certified boats are extremely strong.we had friends with the same boat as well drove it onto a submerged rock at 9knots in tonga, and apart from a scratch or two in the keel, no movement or hull/keel damage resulted. i would be happy to answer any other questions you may have.rob_lennon@hotmail.com.ps thx for the advice on the rudder bearing contact
