Tahatsu 5hp propane
gtg
Sep 12, 2019
103
Catalina, Hobbie 22, 16 Windycrest
It drops below freezing here. Should I run/turn over my water cooled engine out of the water to empty the small amount inside my motor or does it self drain when I raise it up to store it?
Nov 6, 2006
10,151
Not thoroughly familiar with that particular motor, but usually, lifting out of the water will drain it sufficiently.. the more vertical it is when out of the water, the better.. I wouldn't run it out of the water more than 15-20 seconds to avoid frying the water pump impeller.. Your owner's manual might have a suggestion on how to drain it.
Ya might pull it through a couple of times without starting out of the water .. might help draining
3,841
Corsair F-24 MK I Deale, MD
I've been running small Merc/Tahatsu motors for decades. I never winterize in any special fashion just tip them up. (I sail frequently, all winter, mid-Chesapeake). They drain. Never had a problem.
Likes: kloudie1
