E
Ed Schenck
Finally did it. I took off the teak tops to the dorade boxes to see what you guys have been writing about. Sure enough, rotted plywood in there. The drain holes on the back of the boxes are too small and get clogged I guess. So, like the rest of you, I epoxied the inside while trying not to plug the holes or mess up the drainage. I took the tops home to varnish along with the horns. Did someone say they were able to paint the cowl vents? I would like to replace the vents with Nicro solar vents which would do away with water in the dorade box. Someday.While I was there all day Saturday I also removed the staysail traveler and teak mount. The end screws were not holding any more. I drilled all the holes to 3/8" and filled with an epoxy mix. I'll also varnish the traveler mount. Amazing how good that teak looks on a 1979 boat.Woouldn't you know that Saturday was one of the best sailing days of the year.
