it's a PITA...
...but it's there for a purpose, so you just have to work around it. We raced a Peterson 34 and it had a removable inner forestay, which wasn't used (thank god) in light wind conditions. Detaching it cleaned up tacks w/ the genoa and really, really helped with spinaker sets, 'cause the stay just added complexities to the visual mess.That said, the inner stay helps stabilize and prevented mast-pumping in moderate to heavy air and in both those conditions the headsail, particularly the clew, would still scrape/drag by the inner stay w/o hanging up.A word of caution: thankfully I wasn't on board to witness the event, but an almost new borrowed mylar #1 split during a trial run for fit & shape with a startling 'boom!' as a result of a little, itty-bitty wirebarb on the inner stay that just barely scored the sail's surface. Plenty of weakness imparted to make it part when put under load. And yes, "check for stains" was appropriate as the crew doused 2 sails.
