L
Louis
I attach the cringle just above the tack with a shackle and pin to the gooseneck. Is this correct? Should it be rigged like a cunningham? Also what is the proper way to use the outhaul I have mine set tight and leave it. Should I be easing the outhaul in lighter air, tightening in heavy wind? Will it make that much of a difference. Just One more question on the 23.5 is the center of effort fore or aft of the center of lateral resistance on a 23.5?
