Two seasons ago I had my alternator replaced. I went from the standard 55 AMP Motorola to a 70 AMP Leece Neville. The only problem is my Tach has been off ever since. The mechanic who installed the Alternator had no idea on how to reset the Tach to make it right. Is this an easy fix, can it be reset? I cannot even remember my original idle or top end RPM's. It is important to know the exact numbers as I just replaced my Prop and would like to know if there is a difference. Also, as an engine ages I want to be sure there are no changes going on. I have always relied on the Tach to reassure me the engine is performing properly.
