Tachometer working erratically
Hunter 36 Williamsburg VA
The tachometer on my 2007 Hunter 36 which has over 1400 hours on its 3YM30 Yanmar works erratically and jumps all over the place. Sometimes it "pegs" all the way over and sometimes just does not register. Seems like an electrical feed problem? I'm not an electrical whiz and welcome any suggestions to remedy the situation. Thanks!
Nov 9, 2009
69
catalina 25 wing keel rutledge tn.
The tachometer has a sending unit that should be located over the flywheel. The unit will have wires that plug into it. Carefully remove the wires one at a time. Note or mark wire locations. Carefully clean the connections with a small piece of scotchbrite pad or emery cloth. Spray the connections on the unit and where the wires plug in with WD40. Reconnect and see if this corrects the problem. If this does not help then you will need to test the sending unit. Test as follows. Remove and label the wire connections, then using a multimeter ,measure the resistance of the sender. The resistance should be 1.6 kilohms. If the resistance is incorrect, replace the sending unit. If the resistance is correct then check the wires leading from the sending unit to the tachometer. If everything checks out, then the gauge is probably faulty.
Nov 9, 2009
69
I forgot to tell you to make sure the wire connections on the sending unit are not loose.
